Need help to update Kaspersky
I have no internet connection at my home,
Please explain is there any way to update Kaspersky antivirus offline.
Yes you can update Kaspersky if you have no Internet connection. For this:
You will notice that folder location has been added below Kaspersky Lab Update Servers.
Uncheck the Kaspersky Lab Update Servers and check the folder location i.e. The 2nd option and click OK.
Later you will have to contact again your friend or professional for latest updates and do the same process again.
Hi
This is Me.
It is one of the big problems for You. Because it is not possible for anyone to Update anti virus without an internet connection. It is too easy to update your Kaspersky.
You have the need for an internet connection. From your friend or any relatives. After you can Update it. If you are using Laptop you can take it to your friend or relatives.
If you are using desktop You can take your CPU. For update this anti virus. It is impossible for you to update Kaspersky without internet connection. If your zone is good of connection you can take a modem from your friend.
If not you have a need to take your product to your friends or relatives house.
