Need help in using Android phones
Hi, I am using an Android phone. I want a digital clock app widget on my home screen, but it seems it is not supported. So I need some android digital clock tutorial for this, please give me some suggestions. Thanks.
Best Answer by Huffman Serafin
Answered By 0 points N/A #188629
                First, you need to know what version of android phone do you have, if you already know what it is, the next step is download Digital clock applications for android cell phone through the internet. Try this link for the download https://play.google.com/store/apps/details?id=cz.kinst.jakub.clockq&hl=tl. You can also search for other applications or games that you want on you Google app and play store.
Hope it helps.
Answered By 0 points N/A #188630
Hi Paul,
    There are a lot of Digital clock Apps for android. One stand out is Digital Clock Widget this is highly customizable you can customize almost everything from fonts, background, alarm and language support. Another one is ClockQ Digital Clock Widget, this can be embedded on your home screen however, the font that was used is larger than other information on your phone. Lastly, you might want to check the Animated Analog Clock if you somewhat got tired of your digital clock on your screen. Hope this choices can help you decide.
Answered By 0 points N/A #188632
Thank you for the question. I've searched apps for your concern: You can download ClockQ – Digital Clock WidgetDigital Clock Widget Digital clock Xperia™ NXT 3D Digital Weather Clock DIGI Clock Widget and Search Android Apps.
To download an app. You need to locate your Google playstore app on your mobile android phone and then after locating the Google playstore app (it is a white market bag with play button in the front) login your Google account provided by a pop up window for your sake and it will bring you to the list.
On search button (the usual magnifying glass icon) key in, "digital clock" and press enter, all digital clock widgets that are available for download will be displayed and available, also, the apps are ranked from highest to lowest so you can have less time finding the best one.
