lynn sinky
Posted on - 03/26/2013
Hi friends , I am working in an office. In office. I have to work with google docs plugin. Is grammar checker is possible with google docs office plugin. Is offiSync is supported by google docs. If so, please provide me the steps to connect google docs to offiSync. Is plugins are really possible with google docs. Is it is true,? Please support me with relevant answer and steps that are required. Thanks.
Need help in using Google docs Plugin with OffiSync
Hi Lynn Sinky,
Greetings!
Google Docs has its own spell checker but it can't detect grammar usage. Therefore, you can use Google Chrome because Google Chrome has its own spell checker and helps less grammatically savvy among the users. Furthermore, you can install extension or plugins for Google Chrome which provides spell and grammar check including spelling and grammar check in Google Docs. Please visit this site. OffiSync is also supported by Google Docs. It allows users to save or access their work in the Google Drive.Â
I hope you enjoy it.
Jose D Dunn
