humay
Posted on - 08/22/2011
Hello!
I have an issue to discuss with you guys , hope i will get a good solution. I have made backup of my data using Norton Ghost's exe file , which can be located from windows crystal hiren cd option.
As you know it works only during boot process. I have to backup my data while running my operating system , for this purpose i have downloaded norton ghost setup , and install it.
The following screen appears when i tried to do something , if any knows why this appeared
and how to overcome this error , i would be thankful to him.
Norton Ghost
Status Details
No recovery points exists for (C:)
Andrew79
Need help in using Norton Ghost.
Norton Ghost is a wonderful backup software. It will help you to getting backup. You are using the trial or promo version of Norton ghost. That means you are not using real or licensed version of Norton Ghost. You have to buy a real (licensed) version of Norton Ghost. You also have to update your Norton Ghost through Internet. You have to give update to your Norton ghost. And also have to start the Backup wizard of the Norton Ghost before starting to take backup of your computer. You can get backups easily than any kind of software. I think you have got your answer.
