Need Help in Visual Basic Express
Hello Dear,
Here is the necessary code for you, hope this may prove helpful to you:
[case 1]
Msg "Hi"
[case2]
msg "hi"
Now you have to place these items on another dialog.
Though it seems like:
[case1]
Msg "hi"
… —->Place a new one and open that.
[case2]
Msg "hi 2"
Now try this
Code:-
Private Sub Command1_Click()
Dim newe as Integer
newe = Newevent.EventList(Eventnum).ListCount
Newevent.EventList(Eventnum).AddItem "<Msg>: " & Text1.Text, newe
'This bit is OK, places the message.
If Newevent.EventList(Index).Text = "…" Then
Newevent.EventList(Index).List(Newevent.EventList(Index).ListIndex) = "…"
Newevent.EventList(Index).List(Newevent.EventList(Index).ListIndex) = "<Msg>: " & Text1.Text
'Only one thing to happen for a Case
'Need it so you can have more than 1 Message under
'case 1, case 2,etc… (Move every ListItem down 1?) -Chris
Dim Position
For n = Newevent.EventList(Index).ListCount To Position + 1 Step -1
Newevent.EventList(Index).List(n) = Newevent.EventList(Index).List(n – 1)
Next
Newevent.EventList(Index).List(Position) = "…"
End If
Exit Sub
Unload events
Unload Me
End Sub
Private Sub Command2_Click()
Unload Me
End Sub
Thanks for having your time
Notifications
