Need a help with windows media player
when I am trying to play AVI files in windows media player,it pop up error message saying “unsupported file format”,please anyone can help me to resolve this error
Basically, the default media player of Microsoft Windows which is Windows Media Player can only play WMV, MPEG, and some Windows AVI files. If your Windows Media Player prompt you with an error when playing an AVI file then maybe that AVI file is not encoded with a Windows AVI codec. This can happen if the video file was created using DivX or Xvid video codec.
These video codec save the file in AVI format and if this is the case, your Windows Media Player may not be able to play the video. There is still a way you can play the AVI file written in DivX or Xvid codec on your Windows Media Player if you install an application that supports these codec like a video converter.
Normally, a video converter is packed with different video codec which when you install, some of the formats will be adapted by Windows Media Player. Try installing ImTOO MPEG Encoder.
