mario yulia
Posted on - 04/13/2012
It would be my first time to travel to China next month and I'd be staying there for 6 months.
I am aware that a lot of sites are blocked in China but I need to use the internet for work most of the time so I wanted to know if anyone here can recommend a very good VPN provider that I can avail during my stay in China.
Need highly recommended VPN providers
My recommendation for you is to use Hotspot shield. This is a freeware.
This software uses data encryption method which makes you difficult to track in the net. It is an impenetrable tunnel that masks your web browsing activities from snoopers, intruders, ISP’s etc. Since it is freeware, you need not to pay anything for it like other programs.Â
Hotspot shield is fast and free. But you will get an intrusive advertisement for using it for free.Â
To remove these adds, either you can use ADBLOCK extension on your browser or can buy the premier version.
Thank you Tarhu Walsi for your solution! Also for the link of the Hotspot Shield.
You were right about the product.
It really gives high recognition.
I also installed AdBlock plus like what you said.
Many thanks TechyV!
KolaLike
I recommend to you http://www.hideman.net
With Hideman software you can encrypt your WiFi data, hide your IP and protect your privacy on the Internet.
Hideman – ideal solution for protecting your privacy and security on the Internet. Using Hideman you can:
Become truly anonymous on the Internet. Your IP address will be replaced by one of our servers, and your real location will be untraceable.
Protect your data in an unsafe WiFi network. Interests of intruders increased during the rapid growth of WiFi hotspots. Leave them with nothing with help of reliable 256-bit encryption.
Clean up internet of advertising networks.
P.S. When I travel in China I use Hideman software. I like it because fast speed and have encrypt traffic. Also have free 2 hour during the week. 🙂
KolaLike
When I travel in China I use http://www.hideman.net. I like it because fast speed and have encrypt traffic.Â
Someone have free 2 hour in week. 🙂
Llenkova
Hi Mario,
I recommend you to use HOTVPN. It is very good. No blocked sites anymore while I travel. Â
Easy to use and customize VPN client, good prices, friendly support team. You can find out more about it following this link here http://www.hotvpn.com/. Â
All my friends also use this service.
Have a good time in China!Â
