Hello expert, I am learning about Joomla and I have to create a website using Joomla. So I need to add chat gadget into it. But I don’t know the source code to do that. So expert please give me the chat html source. Please give me the HTML code about chat box. Thanks.
Need HTML source code for chat box
One of the beauties of using a CMS (Content Management System) such as Joomla is that most of the time no coding is needed especially for simple websites.
Joomla provides tools called extensions which you can use to expand your website. One such category of extensions is that for chat-boxes.
This site names five such extension but you can find more at the Joomla Extension Directory.
Easy as that unless you want a custom made chat-box.
Hello
Have you heard of html-kit tools, these tools can create a discussion group for sharing source code and chatting. Please follow the simple step below for get started
1. Open html-kit tools on the first computer
2. Select tools group discussion
3. Select a new discussion server from the main menu
4. Then enter a title for example code chat gadget and click on ok.
Then, in the second computer, perform the same process above. I believe this will solve your problem.
Please note that the only thing that will not make this process stated above to work well is when the network traffic is blocked by fire ware. Thanks and good luck.
