Need Info about new padfone from ASUS
Asus Padfone is the first Smartphone that can be slotted into a tablet docking station for a larger view – the 4.3-inch Smartphone just transformed into a 10.1 tablet. This tablet is supported by Android 4.0 Ice Cream Sandwich. The Padfone measures 128 x 65.4 x 9.2 mm while the Padfone Station is 273 x 176.9 x 13.55 mm.
There is a flawless transition between the two devices because of the DynamicDisplay technology – the application remembers where you stopped and keep it up to date so that you can continue to play it again when you need it even if you are switching between the two devices. It has an 8 megapixel rear camera with back-illuminated CMOS sensor for defining photography and high definition multimedia interface for video recording.
The Padfone battery life is up to 63 hours but can be extended to 102 hours if it is plugged into the Padfone station. It can have 16 GB to 64 GB Flash storage plus 32 GB free online storage for 3 years. It uses Qualcomm 1.5 GHz Snapdragon S4 dual core graphic processors to obtain the best performance for gaming, video and photos. Aside from the Smartphone and docking station, the product package includes a Padfone Stylus Headset and Keyboard – converting the tablet into a notebook.
The Asus PadFone was announced in February of 2012 and was released around June of that same year. It operates on 2G and 3G networks. It measures 128 x 65.4 x 9.2 millimeters and weighs 129 grams or around 4.55 ounces. It also has an optional PadFone Station with 10.1-inch screen display and 1280 x 800 pixels screen resolution.
It has a super AMOLED capacitive touchscreen display with 16 million colors and 540 x 960 pixels screen resolution protected by Corning Gorilla Glass. It has 1 GB RAM and a MicroSD slot that is expandable up to 32 GB. The Bluetooth supports A2DP and also includes a v2.0 MicroUSB port.
It has an 8 megapixel primary camera with 3264 x 2448 pixels resolution and features LED flash and autofocus and capable of doing video recording at 1080p. The secondary camera supports VGA. It runs on Android 4.0 Ice Cream Sandwich [ICS] and can be upgraded up to 4.1 Jelly Bean.
It is powered by a Qualcomm MSM8260A Snapdragon chipset on a dual-core 1.5 GHz Krait processor and Adreno 225 GPU. It is integrated with gyro, accelerometer, compass, and proximity sensors. It supports HTML5 and Adobe Flash for its internet browsing. It also has a GPS that supports A-GPS and is also Java compatible via Java MIDP emulator.
Standby time is up to 360 hours on 2G and 370 hours on 3G while talk time is up to 15 hours 40 minutes on 2G and 8 hours on 3G. It costs around 300 Euros.
