If my system crashes anytime, Can this software back up my all recent work automatically? What is VSS function in it? Is it only windows based software? Can this software back up any external drive? What is the reload function available here? Describe about its system back up and folder backup. What is a dynamic disk volume backup, it has? What is “universal restore” recently added into this? What is PXE network booting? Thank You
Need information about AOMEI Backupper Standard 2.5.0
The AOMEI Backupper Standard 2.5.0 has more features and specifications are listed below, It has system restore and backup facility, Disk restore and backup facility, partition and volume backup and restore facility and files and folders restore and backup facility.
Three types of back are used scheduled backup, differential backup and Incremental backup. It is supported restore system and dissimilar hardwares.
The disk clone and partition clone available even system clone also available. The supporting operating systems are windows server 2003, Windows server 2008 and advanced versions.
The AOMEI Backupper Standard is a backup application. Programs like this give your data protection against unwanted corruption and data loss. You can back up your files and other data to another drive manually or automatic using a scheduled backup task. Among its features include:
- System backup – allows you to back up all files on your system drive or drive C especially the operating system or the Microsoft Windows operating system
- File backup – allows you to back up specific files or important files to an external drive
- Disk backup – this allows you to back up your entire hard drive
- Partition or volume backup
- Automatic or schedule backup
- Incremental and differential backup
- File sync
The AOMEI Backupper Standard is available in three versions or editions: Standard, Professional, and Workstation. The Standard edition is free for everyone. This is their free version. The Professional version costs $39.95 while the Workstation edition is at $49.95. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. If you want to try it, download AOMEI Backupper Standard.
