How is Output Power Capacity in APC Power-Saving Backups Pro 1000? What is Nominal Output Voltage required? What is Surge Protection in it? How long cord length is available? Describe about its battery type. How is the recharge time and back up ability time? Is there any alarm system while battery low? Describe its physical explanation. Is there USB port available? What is Automatic self-test system? How can I know Battery failure notification? Thank You
Need information about APC Power-Saving Backup Pro 1000
Hello Willie!
The nominal output power capacity is 120V. Using USB cable for connector. NEMA 5-15R is the surge protector for it. Nema is supported by three-wire grounding devices with maximum 125V output. The length of the cord is extended up to 1.83 meters. The recharge time is up to 8 hours and the backup ability time will depend on the wattage load. For example a device with 200 wattage will be up to 25 min to 30 minutes back up time. The alarm will notify the user for overload and outages. USB port is available for the AVR. It will provide you warning or alarm in battery failure. Automatic Self-Test System will notify you if one of the battery will fail.
