Need information regarding top 5 annoying things with Smartphones
I need to know about the top 5 annoying things with smartphones,
Can anyone please list the top 5 annoying things which are common in smartphones?Â
Top five disadvantages of smartphones are listed below:
Small Screen Size: Smart phones are often used to surf websites, but their small screens will force you to make your eyesight weak.
Awkward Keyboard Size Although the keypads seem to be copies of the QWERTY keyboard, you cannot use them comfortably, as one of your palms will always be holding the phone.
High Cost · Along with the basic cost, an Internet connection is provided for a higher cost.
Website Access · WAP is used to convert website size to phone size, but not all websites possess WAP applications.
Work-Life Balance These phones can be carried anywhere, so even if you are out of your office, you are partially there, as you will be checking emails, or answering phone calls on a regular basis.
