I have a few websites that are published using TMG. For some reason, they aren’t matching. When I try open one from an external IP and view the log (below) it goes to the default rule. Does anyone have ideas why these publishers are getting ignored? Also port 80 is forwarded to the external int of the TMG server 192.168.201.253.
Need input on the issues with my websites
Hi Campbell, your query is easy to solve, the publishers are ignored because of the IP addresses and the TCP ports configured. This also depends on the public name of the websites.
What you need to do is to authenticate the websites' IP to the specific domains and the servers. Ensure the proxy is also assigned to the specific network or server and try restarting the website. The IP addresses will be recognized. It should work
Thanks
