sammy
1070 points
Posted on - 06/04/2011
Hello to all here. I need help on installing MS Excel. I want to setup MS Office XP without having to type the product key again and again. Let me clear the need. I have Office XP software. It seems boring to me to put the product key in every setup. Is there any trick to setup office without the product key? Please share it to help me. It will be great help for me as well as for others also.
Installing MS-Office without typing the product key repeatedly
Hi Sammy
The solution for installing Microsoft Office without having to type the product key is as follows
Install Microsoft Office without the product key, proceed as follows:
1. Go In Windows Explorer menu, browse to C:Program Files Common Files Microsoft SharedOFFICE12Office Setup ControllerProof.en and then Right click on Proof.XML file, then Open it in the right click menu.Then In the Open window, select Notepad to open the XML file and Scroll down to the bottom of the Proof.XML to locate these lines
<feature Id="SetupXmlFiles" Cost="1248″><optionref Id=”AlwaysInstalled”/></feature>
And then Change the AlwaysInsalled to neverInstalled so that the line looks like following:
<optionref Id="neverInstalled"/>
Next Save the Proof.xml file in your system and you are no ready to launch and use Microsoft Office applications such as Ms Word,Ms Excel, Ms PowerPoint, Outlook and etc without prompting for activation
