Need to know about belkin device webpage
I want to know about belkin device webpage so that i can configure belkin router and wireless with my device. I want to pick up interference from local wirelesss networks. Where can i get belkin device webpage to configure belkin router?
Answered By 40 points N/A #136444
Dear Larry
Majority of the routers nowadays are very easy to configure. If you look at the back of the router, they are labeled accordingly from the power, LAN, etc. Just like assembling a PC, all you need to do is to make sure that you put the appropriate cable to the socket and you’re good to go. As for the webpage, below is the official Belkin website:
http://www.belkin.com/networking/wireless-routers/easy-setup/
The images on the said page should guide you on how to properly set-up everything. Please be sure to have your start-up disk handy because you will need it to finalize the configuration. Should you need other information, you can use their support page below:
http://www.belkin.com/us/support-article?rnId=6939
Hope this helps,
Curtis
