I have smart notebook and i have installed math tools.
Now math tools asking to be registered. What should i do now?
Where i can get smart math tools registry ?
Need to know about smart math tools registry
Hi Marco P Hamm,
Please follow the step by step instruction:
1. First download the file regfix.zip
2. Then unzip the file.
3. You will find two .reg files there. If your computer is running SMART Notebook Math Tools, then click Registry > Missing Values > With SMART Notebook Math.reg
4. Or if your computer is running the trial version then click Registry > Missing Values > Without SMART Notebook Math.reg.
First you have to make sure that the package you will install fulfills your notebook requirements.
For a complete install of the SMART Notebook, you have to get these 4 packages:
1) SMART Notebook.msi
2) vc_red.msi
3) SMART Product Drivers.msi – Keep note that before installing this package you have to install Microsoft Visual C++ 2008 SP1.
4) install_flash_player_10_active_x.msi
In order to have a licensed Tool you will have to purchase the registration key for full activation.
1) Go to Help menu and select "Check for Updates"
2) Once update starts, the available software will be listed.
3) Active the one that you want to enter the registration key.
4) Enter the registration key you have purchased and that's it.
