asaiful99
20 points
Posted on - 09/20/2011
I was wondering that if there is a software which can extract email addresses from a website/webpage. It will be very helpful to my business. The software will use "@" to locate the email address and collect them into a spreadsheet. Does anyone have any idea about this software?
Need to know about a software.
I can recommend an email extractor.
You can download this software for free. Try this maybe it may help you.Â
Email extractor is the fastest harvester on the web. Unlike the other email harvesters, Email Extractor possesses all essential features of extraction software, You can collect email like Google, Yahoo, AOL, or other search engine you want.
If this is not helpful, try to hire some employees to make your business bigger.
Here is the answer to your request.
It does extract emails and collects them into a spreadsheet.
This should make it easier for you to deal with your business.
I am glad to have helped.
I tried the link myself and downloaded it and it worked perfectly!
Here is the link:
You may also try this as an alternative:
Good luck and more power!
Puckett
