Need To Know Can You Fax With Magicjack Plus?
Hi, I am a user of MagicJack software. Now I am thinking of updating to MagicJack Plus. I just need to know if it’s actually better.For example, can you fax with MagicJack Plus?
The truth is that MagicJack Plus does not have its main function as faxing. Thus, it is not great or always efficient at it.
But, yes, it is possible to fax using MagicJack Plus. For this, you need to connect a phone to the MagicJack device.
Also, you should have a DSL installed in the line and also, most importantly, before starting, set your fax machine’s speed to slow.
Then, turn off the ECM and start faxing. You can receive faxes on the MagicJack phone.
