Need To Learn How To Disable Norton Security.
I am using a new software on my laptop but it’s not working properly because norton seems to be interfering with it. So I want to know about how to disable norton security
Norton can be disabled in two ways, permanently or temporarily. Since you are only facing a problem with one software, I suggest you disable it only temporarily. Follow the following steps: Find norton security program from a list of programs in the start menu. Click on it to launch. Now, do not do anything within the program, but look for the norton icon in the taskbar. Right click that icon. Now, click on “disable norton”.
You will get a confirmation message which you need to select “yes” in. Later, you can enable it in the same way, by selecting “enable” instead of disable.
Notifications
