Need Light show designer free download .
I need a software package that shows designed lights . It would be a lighting theme or something like that . I need that to design the light show for programmatic reasons .But I can't find it anywhere . Can anyone help me to get Light show designer free download ?
Best Answer by Hodge Trafton
Answered By 5 points N/A #166834
I recommend you download the Q Light Controller Software. Though its improved version is on the line to release, I don’t believe waiting for its release date will help you. This is a controller of lightings / light software, so I’m sure this is the one you are looking for. https://sourceforge.net/projects/qlc/
Hope this will help. Thank you for asking.
Answered By 10 points N/A #166835
There are many free and paid applications you can find and download over the internet. Here are some sites whereas you can find the applicable light show designer for your needs.
  1. Software informer can help you to have applications to download that can incorporate into your video or work. The programs here can also create your own professional slide for the output you want to achieve. But you need to register first before you can download it.
  2. 2000 shareware  can provide the free software you can download for your light show design. You just need to read first each description and choose the right software you need.
