Need a list of all fujitsu hdd diagnostic tool codes.
Can someone give me the list of all fujitsu hdd diagnostic tool codes? I am facing the blue screen problem a lot with Windows XP and would seriously like to get rid of for once and all
If the tool that you have installed is to diagnose physical problems in the computer, then it would function as it is wherein if in any cases the utility has failed. As far as this is concerned, there has been no software that will able to repair this.
What you can do is replace and buy a new driver for it.
Perhaps you try to see and check this site in Fujitsu HDD Diagnostic Tool.
You can also try to read the thread here about error HDD codes.
Hope it helps,
Diane
