Need to manage lion calendar task
I am using mac computer. I need to manage lion calendar task in my device which will separate reminder and calendar apps. How can i manage lion calendar task in my device?
Hi Leborn,
Good day!! Choose File→New Event, press Command+N, double click, or click and drag up or down anywhere on the calendar.
If you double-click or click and drag on the day of the event, you can skip Step 2, and you don’t need to specify the date in Step 3.
Alternatively, try Lion’s new Create Quick Event (+) button. It’s smart enough to interpret commands like “Family Movie at 7PM on Thursday” and create a new event on Thursday at 7 p.m.
Kind Regards,
Lorraine P Goodman
