Eaana Albert
2105 points
Posted on - 07/27/2016
Hey guys,
I want to Convert Square Feet to Gallons of Water. Is there any mathematical formula that I can use to make the conversion without having any problem? If yes, then someone, please tell me.
Need A Mathematical Formula To Convert Square Feet To Gallons Of Water.
First of all, let me inform you, Gallon is a unit of Volume and Square Feet is a unit of Area. You cannot change the Context while performing the conversion. You can convert Cubic Feet to Gallons.
Mathematically, there are Seven Hundred Forty Eight Gallons in One Hundred Cubic Feet, which is also called HCF (Hundred Cubic Feet).
So, when you have to convert Cubic Feet to Gallons, then you have to multiply the desired number with 7.48. You can see one HCF (748 Gallons) water in the figure.
