Need memory Card Recovery 6 activator for full version.
Asked By 190 points N/A Posted on -
I've memory Card Recovery 6.0 software with license file. But the license file is not working. Without it only 200mb data can be recovered. So you know I badly need it.
Will anyone help me out?
Answered By 5 points N/A #163502
Try these steps, maybe it may help you. First, Press the Next button on the Opening screen. On the First screen, it requires you chose the drive where the card is located. After that, choose your camera make. It helps Card recovery know what encryption type names of the files to look for but it is not imperative and if you can’t find your camera make there is generic option. On the next screen, you select the sort of files you are looking for. And finally, choose the destination where your recovered images will end up.
Hope it will help you.
