Need to merge Price range slider !!
I own a jquery website. There is just one thing that it lacks and that is the price range slider. I already have a price range filter in it but need some help on how to merge these two. Any Suggestions ??
Hi Jeviery,
Please visit the following links. You may find your solution.
http://egorkhmelev.github.io/jslider/
http://forum.jquery.com/topic/price-range-using-ui-slider
http://www.onlywebpro.com/2012/02/15/build-a-jquery-range-slider-within-5-minutes/
I hope those sites will help you what are you searching for.
Dear Jeviery,
Using jQuery it becomes simple to manage your code and you can get the price range slider easily. You can have this done by the code that I have attached. You can details and find more help from the author’s site by visiting.
Hope this helps.
Alice
Notifications
