Need a Numerical Linear Algebra Software
Hi expert, I need a Numerical Linear Algebra Software. My operating system is Windows 7. If you know please send the download link. And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages.
Answered By 0 points N/A #186336
If you want to use software that helps you in typing Linear Algebra equations then you need to install Math type software. This will help you in equations typing and printing. If you want to solve problems using software then you need to install the Matlab software and you will be able to type and solve the equations.
You can select one based on your requirements.
Darrel R Gonzale
