Need offline summarize article software like wiki summarizer
I am used with online summarizer named Wiki Summarizer, for summarizing articles found on Wikipedia. Can any one suggest me a summarize article software that will help me to summarize articles in offline.
Best Answer by Baker Mich
Answered By 5 points N/A #153718
Hi Roberts,
I would suggest you the following software for summarizing your article and giving it a more professional look providing enough thing for easy grasping of complex statements and its meaning.
Click on the link below to download and install the software for your requirement.
https://en.softonic.com/s/summarize-software
I can see it’s easy to use and automatic summarizing feature is quietly brilliant.
Hope this helps.
Thanks
Baker
Answered By 0 points N/A #153717
Dear Roberts A. Raymond,
                                             The best choice for a summarizer is MS Word; its efficiency is good and it is very widely distributed. Summarizing an article in Word can be done by choosing Word Options, Customize, and then choose the AutoSummary Tool. You can find a detailed description at the following site: https://support.office.com/en-us/article/Automatically-summarize-a-document-b43f20ae-ec4b-41cc-b40a-753eed6d7424?CorrelationId=1ece5890-6612-44b8-be19-829ccfcf2b2b&ui=en-US&rs=en-US&ad=US&ocmsassetID=HA010255206
Hope to be helpful
Best regard,
