ruiz harrer
30 points
Posted on - 04/03/2013
Since a long time I have been searching for the open source file portal for sharing files which is similar or almost same like filesanywhere.com.
I need it because I do the file sharing often but I need just like that site I liked the most.
If you have any ideas,
Your help would be appreciated.
Need open source file portal
Hey,
LANshare enables users in the same workgroup and LAN environment to share files and folders and also communicate without any central server. LANshare is small about 1.1MB, simple and easy to use.
To download LANshare visit http://www.softpedia.com/get/Internet/Servers/Proxy-Servers/LANShare.shtml.
Syncany is another open source application that enables file sharing and also allow users to back up their data.
points
CKAN, the world’s famous and leading open-source data portal stage. It has very powerful data management system as well with its provided tools helps you to update, publish, share, your data easily. It also provide you each dataset with a huge collection of metadata, and make it valuable as well easily searchable resource. This software is aimed at data publishers wishing to create your data open and available. It free and for download visit this site and enjoy!
