Need open source mosaik video edit program
Hi guys,
I need one mosaik video edit program that will work on my Ubuntu. There are many but I need the best one that work on Ubuntu.
Hi guys,
It is not easy to find a compatible software for all the operating systems but I would like to suggest that you will try this link:Â
http://download.cnet.com/AndreaMosaic/3000-2192_4-10889016.html
to download the software just try it on your Ubuntu operating system, make sure that you already made all the possible recommended updates of your operating system.
I hope this will help you a lot.
Hi Liam,
There are couple mosaic apps available but I recommend Foto Mosaik Edda. You can use your digital pictures from your phone, camera etc. and turn them into mosaik. Foto Mosaik Edda enables you to make mosaik pictures easily.
It works with latest Ubuntu version and you can download an archive from their site and try it for yourself.
