alec hughes
20 points
Posted on - 04/17/2012
I am planning to set up my own FTP site for letting users download my paid text editor software. I would like to try FTP Commander since I learned about its features and advantages a few weeks ago.
However, I don't have experience in FTP clients, and I don't know if FTP Commander will suite my needs. What is your advice on FTP Commander? Will it be worth a buy? Can I use it for my webpage too?
Need Opinion on FTP Commander
Actually FTP commander means an FTP clients for windows. It is a program that has developed by Internet soft corporation. I think, yes you can use ftp commander for your website.
It is helpful much and make easy to use ftp client. I discuss something about it. That might be helpful to you take the right decision.
It offers you a interface that consist of side by site local computer.
It contains a list of many server, make automatic connection with them as your wish. So it makes your website speedy and available to users.
Ftp program can help you to upload or download necessary data for your website within your wish.
The program help you onto drag and drop file transfer, help to pop up problem.
Totally it can make easy customize your website.
For more info about ftp commander visit here- https://en.wikipedia.org/wiki/FTP_Commander
No cost you have to download it. It's absolutely free. But to gain more advantages you can grab paid ftp commander from Internets of- http://www.internet-soft.com/ftpcomm.htm
Or download it's free version visit here- http://www.tucows.com/preview/195124
and here you go- http://download.cnet.com/FTP-Commander/3000-2160_4-10025993.html
I highly suggest you to buy ftp commander from Internets of. It helps you more.
