The camera am using to monitor my shop does not support much zooming of the pictures, does any one know of a pc camera viewer software that can help zoom my pictures more than my camera does?
In need of a pc camera viewer software that can zoom pictures.
Hello Asheley,
I believe IP Camera Viewer software is the software you will finally come up with. You can turn your PC into a CCTV video surveillance hub with it.
It supports over 1500 camera models and basically it works with all USB cameras as well.
You can configure it's all features and most important thing is that you can adjust the pan, tilt and zoom for a better coverage.
Try this! Attached is a screenshot of the camera view of the software.
Download and install from CNet.com. Here is the straightforward download link.
Or go to winsite.com and there'll be a collection of downloadable webcam software with zooming ability.
Just try.
