adam musick
20 points
Posted on - 09/06/2012
In PES 2012 configuration system is Windows 7 Operating System. I would like to configure the PES 2012, is there any way we can do that? And is there a kit free download for configuring it automatically? Need your help
Need pes 2012 configuration of system in Windows 7 OS
I’m not sure what kind of configuration you want for the program since it is only a PC game. Every game has its own configuration and you can find and access it by going to its options or settings maybe, whichever is available. Since you are already using Windows 7 to play the game, you are running it on a 100% compatible platform.
PES 2012 or Pro Evolution Soccer 2012 supports Windows XP, Windows Vista, Windows 7, and Windows 8. And it is also available in iPhone, Android, and Windows Phone. If you are dying to download and play the game, you may download it from softonic® – enjoy software! — PES 2012. You should visit the page for other important information and also to be aware of the hardware specifications needed and also some pros and cons of the game.
