Need picture background DataGrid vb6
10 points
Posted on - 11/05/2012
The BackColor property just connects with the grounding of the unit region-the unused region around that (if units don't fill the control) appears to default to Bind Face.
Is there any manner to set this straightforwardly?
I should set picture background datagrid vb6 then again make the unused territory transparent to the form/container beneath it?
