Need port block freeware portable software
I need a port block freeware portable software which can disable or Block the USB Ports of a PC from being accessed by unauthorized users.
Where can i find port block freeware portable software?
Hello
You can download this simple tool from Cnet: http://download.cnet.com/Disable-USB-Ports-Tool/3000-2653_4-75449410.html
You can restrict operations on your USB port and set password to it. You can restrict writing, reading, writing/reading or you can completely disable it. Also there is option for restricting regedit being edited by other users.
This is very useful and simple application and I recommend it.
Regards.
Hi there
Do not depend on software's, why you need software’s when you can block the ports manually. Follow the steps shown below to block USB ports
Step 1 – Go to start > Run > Type Regedit and hit enter
Step 2 – Find this path
HKEY_LOCAL_MACHINE> SYSTEM> CurrentControlSet> Services> USBSORT
Step 4 –Find Start and Double click
Step 5 –Tick hexadecimal and in Value Data type “4”
Step 6 – Then close the regedit editor
Now your USB ports are disabled and if you want to enable it change the value back to 3
Taylor B Campus
Thank you
