I have a Linksys Smart Wi-Fi EA6500 Dual Band 802.11 a/b/g/n router on an XP 32-bit computer. I'm looking for a program open wifi wpa blocker. I use a WPA security protocol in my router but it looks like that it is not that effective. What is a good program that will block the intruders from accessing my router?
Need program open wifi wpa blocker
Dear Tatyanamaiaa,
To fully protect your router from hacking, you must first of all to control by password, and by making it private and covering a small area. This can be done by giving the router a password and giving the password to users you trust.
But if you prefer on making it opened, you should try to download ZoneAlarm which is very strong software which can help you with your defenses against hackers.
Software URL download site:
https://www.zonealarm.com/software/free-firewall/index.html
Hope this was helpful for you.
Best regards,
Don Muench
