Need a quick overview of Code Compare 4.0.77 software
Can Code Compare 4.0.77 integrated with TFS, SVN, Git, Mercurial, and Perforce? Is it opening source software? Can this Folder be compared and is any merge facility available? Can I integrate with Visual Studio? How does this show compare code line? What is Intellisense in it? What is 2-way text comparison and 3-way text comparison? Is it supported multiple languages such as C#, Java, C++? Can this support Javascript and PHP? Can this software install on Mac operating system? Thank You
Answered By 0 points N/A #171967
                 It is a software designed especially for source code packed built in editor, code folding and merging options. We can work multitabbed layout, performing the comparison operation.
                 The supported file formats are SQL, SLN, and plain text file format.
                 We can export the file format and print it. If the similar data have not selected the two source code files are highlighted in blue.
                 If we look advanced options, outlining, code comparison line in, line Or code in code we can check the special utility software named professional edition of the utility.
