Need to recover the password of windows 7
I am using Windows 7.  Few days ago my mother said to me to keep the laptop locked by using a password. As per her suggestion I created a password for my account. My account is admin account. Now I forgot the password. I can’t remember any clue of the password. What can I do to recover the password?
Best Answer by berrycom_1439
Answered By 0 points N/A #99036
Having this problem is common. First thing first, have you tried the guessing method? Well, who knows this might saved you. This is the common and easiest solution. Try it.
But if it's not working then we will proceed to resetting of password using Window 7 password reset disk. Well, lucky for you if you have this disk, it's just easy as 1 2 3. I assume you have one. Steps to be follow on how to do it.
  • Enter your guess password, if still wrong and you cannot log on, then a pop of windows will appear telling you the password you is incorrect. So, click OK.
  • Click RESET WINDOWS PASSWORD
  • Insert your disk
  • Have your new password by following the "PASSWORD RESET WIZARD"
  • Then viola! you can log on now using the new password.
Answered By 0 points N/A #99037
You need to get help from 3rd party software for your Windows 7 password reset. It’s the best choice to quickly access your computer again in this situation. You can use Windows Password Breaker. This is an effective Windows password reset tool, which helps you create a Windows 7 password recovery bootable disk (CD/DVD and USB flash drive are supported) to reset password for windows 7 when you forget your password. Follow the following steps.
  1. Download Windows Password Breaker professional and install it.
  2. Run the program and burn a bootable password reset CD/DVD or USB drive.
  3. Reboot your locked computer from the burned CD/DVD or USB.
  4. Reset Windows password to blank.  Then you can log on your windows 7 with no password. You can follow the user guide on Windows Password Breaker Professional.
NOTE: You don't need to get a 3rd party software if you make full use of Windows features, creating a password reset disk or system repair disk in advance (Before you forgot your password).
