Need Samsung sme file conversion tool
Hi all, I am using a Samsung mobile phone, in which I use software named Samsung Kies that came along with that, to backup all my SMS's . This software creates a .sme file, to store the backup. I was wondering if there is any other software that can open these files, or is there any Samsung sme file conversion tool that will convert it into a readable format.
Best Answer by Malone Toby
Answered By 0 points N/A #156929
Hello Baker,
Yes there is two options for opening the .sme file. First one is to converted as you asked, there is a converter for this files. And the other solution is to use a software called Abylon reader. It is a software that is opening a lot of files including the .sme files. I will be happy if this two options help you. I will give you links for the two activities.
http://download.cnet.com/Abylon-Reader/3000-2092_4-142302.html
http://www.2000shareware.com/downloads/samsung/sme/file/converter/
Answered By 590495 points N/A #156930
The SME files or .sme created by Samsung Kies when creating a backup of your mobile phone is associated with SmartEncryptor Encrypted Archive [SmartSoft]. One way of opening an SME file, if you don’t want to use Samsung Kies though it is a Samsung Kies file, is to use FileViewPro. Download FileViewPro 2014 to try and test it on your SME files.
It supports Windows 2000, Windows XP, Windows Vista, and Windows 7. Microsoft Windows 8 and later not supported. With FileViewPro, you can open any kinds of files such as videos, documents, music, pictures, and more. Among its features include the simple drag-and-drop interface and the ability to open more than 150 file formats. It is by the way created by a Microsoft partner.
