Need to scan a document to PDF and edit it seamlessly
My old OCR program stopped working for some reasons and I need to have the best going aside from Adobe Professional. Do you have any suggestion? I need to scan to pdf and edit the document.
You can try A-PDF OCR to this which looks very easy to use. You can download it from the below link:
http://www.a-pdf.com/ocr/a-pdf-ocr.exe
After installing click on “open pdf” to choose scanned pdf files from your computer, in OCR, chose a language and click OCR all pages. The OCR text will be displayed. From Edit click OCR text and you will be able to edit directly. Save the text file to output the edited text.
If you need to do some OCR on your documents, you can use the latest ABBYY FineReader. The latest version at the moment, ABBYY FineReader 15, supports Windows 7, Windows 8.x, and Windows 10. It requires 1 GHz x86 or x64 or faster processor with SSE2 support, 1 GB RAM, 1.2 GB free space, 1024 x 768 minimum screen resolution, and internet connection for product activation.
If you want to try the program first, you can download the ABBYY FineReader 15 Free Trial. The trial version works for thirty (30) days counting from the date you installed. The free trial is limited only to process up to 100 pages. Among its features include:
