Need scaricare hp setup file
Hi expert, I need scaricare hp setup file. My PC model is HP and operating system is windows 7. Please send the free download link. And send some helping tutorial explanations for how to use it, Special features, Main advantages and disadvantages.
Answered By 30 points N/A #167154
Hello Dear Kim,
Thanks for asking us.
Dear the Scaricare HP setup that you require is in fact a supportive software introduced by HP company.
This software is specially design for HP computers.
The benefit of this software is this that it troubleshoots the computer automatically if any problem occurs.
The official name of this software is HP Support Assistant. It is usually installed in HP system with registered version of windows.
This software works like Action Center in windows 7.
There is no side effects of the HP Support Assistant.
Click the link below to download this software and get more information about it.
http://www.softpedia.com/get/System/System-Miscellaneous/HP-Support-Assistant.shtml
I hope it will better help for you.
Thanks
