Need a script writing software
Hello everyone,
I am writing a story. For this I need a script writing softwares where I find some templates, images, emoticon font etc. Please help me with finding the software.
Hello everyone,
For writing work, you can use general software like Microsoft office professional plus 2013. It can fill your above criteria like templates,images etc. Other softwares which is especially built for script writing are also available in the internet. You can use Script frenzy. To know more about this software visit the following link and buy this software.
In this link you also get many other script writing software like Storist Software.
Thanks
Hello Catlin,
As many other writers you might have tried writing your stories using Microsoft Word. But here are some special script writing software that will fulfill your needs like
1. Adobe story, it helps you to write scripts and screenplays very fast. It is apart of adobe cloud ,so it must help to write your script in your desired manner ( https://story.adobe.com )
2. Scripped, its a great site to write scripts and you can also earn money from this site. ( https://writerduet.com )
3. Screenwriting pro software, you can use this site to write script for films, stage shows etc. ( www.screenwritingpro.com/ )
4. Storyist, you can use this to edit your writings ( http://storyist.com/index.html )
4.Script Frenzy, here you can find many other writing software ( https://goodinaroom.com/blog/script-writing-software/ )
I hope you got desired software.
Thank you.
Berta R Cahill
