Need a SDHC card encryption software
Hi everyone,
I store many important documents on SDHC card on my mobile. But there is a problem of accessing it, Is there sdhc card encryption free software on the net? Please reply me.
Hi everyone,
Dear Marco,
Encrypting data on SDHC cards depends on the operating system on your mobile because the encryption software will be installed on your mobile.
For example if your mobile runs on Android system you can set up software like "File Vault".
"File Vault" is a free security tool with it you can encrypt and hide all types of files on your device.
FileVault is password-protected. The files encrypted by FileVault can't be shown in any file explorer software.
And here is some software that enable you to recover SDHC data if lost for some reason:
1. EaseUS Data Recovery Wizard Free Edition: Supports Windows 2000/XP/2003/Vista/2008/Windows 7.
2. Sony Memory Stick Data Recovery 3.0.1.5: Support Windows.
3. Card Data Recovery 2.3: Supports Mac OS.
Notifications
