As the title says, I have a Seagate Hard Disk Drive but it was damaged and a friend of mine somehow made it work.
He told me that I must remove some bad sectors, and it will be as new but smaller.
I have no idea how to do this, but I am sure with your help I will make this Hard Drive work.
So please help me to get Seagate HDD bad sector remover software.
Any help or suggestion would be appreciated.
Need Seagate HDD bad sector remover software
There are many bad sector removing tools available on various website. The best software I found and it worked for me is MAXLLF. It performs low level formatting of hard drive with bad sector removing. Note: Please take your hard drive back because it will make single partition of hard drive and all data will be lost and non-recoverable. After running this software you have to re-create the partitions.
Hope this will work fine on your infected hard drive.
