Need software for comparing iso files in terms of data.
Is there a good software which can be used for comparing iso files. I want a software which can compare folders, images etc.
There are many softwares available in the market through which you can compare .iso files. They are basically disc images. There are many free softwares also available to compare .iso files. Some of the softwares that can compare .iso files are:
1. WinRAR – You can use winrar to browse through the contents of the iso file. Using winrar you can only browse through the contents of the iso file and you will not be able to use the file.
2. MagicISO – Using MagicISO you can see the contents of the iso file. You can also mount the iso file and use it as a disc.
3. Daemon tools – This is another software which can compare iso files. In this software you have to mount the disc image file first to see the contents of the iso file.
If you only want to see the contents of the .iso file, you can use WinRAR.
