Hello Experts,
I need a software to copy pen drive automatically to a specified folder on a predefined drive for windows XP.I need this software for syncing the contents of pen drive with my PC. Please help me out because this is very important for me.
Need Software to copy pen drive automatically on Windows XP
There are a software what you needed, it will copy data from your pen drive and store to your pre-defined drive, that you will save. You can say this is a hidden data copier and it can copy maximum 8 GB data in a go. In default the content will be copied to “C:WINDOWSsysbackup”. Here is the link for the software :
https://od.lk/f/MV83NTExMDc0XzhmaTdO
Let me know if this is what you are searching for.
