Halton Roy
50 points
Posted on - 03/05/2013
I have found quality center word add in error in my internet explorer. I have tried to lower on the security settings without any success. Every time when I start a word I have faced the error. Why is the error occurred and what is the solution to prevent ?
Quality Center Microsoft Word Add-in Error
User is not permitted to export this type of data. Please contact your administrator.
Need solution about quality center word add in error?
Hi Helton,
I guess you have HP-computer. I think you can find this link useful:Â https://admhelp.microfocus.com/alm/404.htm
Be careful, this link may not work after few months.
If you tell me what versions of Windows Operating System and Internet Explorer  you are using, I can find many better solutions to your problem.
Best.
Hi Halton,
You can prevent your problem having a very easy way. There are a whole range of browser & people often use the most latest version of popular browser. As you know internet explorer is created by Microsoft. There are many shortage of plug ins in mentioned browser. So i think its better if you use Firefox, Google chrome, SR iron any many more by searching. Let's try and i expect you can over come.
Good luck.
