Need some guidance on using Ajax upload photo
Hello.Â
Can someone give me some examples or guide on how to use Ajax on uploading photos? Does this need to use jquery? I would be so grateful if you can provide me some Ajax upload photo tips.Â
Hello.Â
First of all you can either use HTML, PHP or JavaScript to upload photos.
Most of the developers uses snippet of certain scripts.
Here is an example-
You can use this on your HTML page to start uploading immediately.
You can use Ajax and JQuery to upload an image to the database.
You will need an internet connection to see the program running correctly since the Jquery files are added through Google Apis.
You can still download those files into your local machine in update the code with local path.
