Need some help to buy a good eBook reader
Hi guys , I am planning to buy an e-book reader on next Sunday ,please tell me what are the things do I need to consider when choosing a particular model
Here are the things that you need to consider when buying or choosing a particular eBooks reader : 1.Screentype – there are two types of eBooks reader today one has the LCD screen like the amazon kindle fire and the other one is the e-ink style or the paper like look like what you see in the later version of the Kindle.
There are certain advantage and disadvantage of using an e-ink style one advantage of it is to reduce eyestrain caused by the glare of the sun and greatly improve battery life but the disadvantage of using an e-ink reader is it requires an external light source for reading when dark. 2. Size and weight – if you are a type of person who read books for a long hour then I advised you to get a kindle eBooks compare to any other book reader it only weighs 8.5 ounces 3. Interface – Controls for eReading devices are typically based on either buttons, touch screens or a combination of both. Button-based controls require less power and are more accurate but can be more cumbersome to use.
Touch screens are more intuitive but can be laggy, smudge-prone, and typically suck more juice from your battery. The latter appears to be gaining popularity as the interface of choice, though, even for E Ink-based displays. 4. Capacity – This determines just how much media you can fit into your device at one time. The higher the memory, the more eBooks and files you can fit in. 5. Formats – The more formats a device can play the better. Popular file formats include EPUB, PDF, PRC, MOBI among other things. 6. Battery Life – Depending on where you want to read, battery life is an important consideration. 7. Price – It contributes the main factor when buying an eBooks reader.
Hope this would help 🙂
I have read your problem and a best solution for your problem which I will recommend you is,
Following are the best e-book readers for the windows. Which you get easily from the internet as well.
Like:
Mobipocket reader
Microsoft reader
FBReader
iSilo and
Haalireader
martview for PDFs
Although there are many others softwares as well in the market. Which are also easily available in market and on the internet as well. But I have given you the best and the latest softwares specially.
Adobe reader is also one of the best software.
Hope so you will get the solution from my suggestion.
Good luck for your future working.
