Need some help with file format “fxg”
Hi guys , I have some video files at the end of the file name it says fxg , I never heard that file type before , please can someone suggest me a player to play those video files
Thank you
Thank you
Hey Liza!
FXG stands for Flash XML Graphics. This is the file which is developed by Adobe system . This is the file which was first used by Adobe Flash and Flash player.
Now the question is how to open this file.
There are four programs which can open these files. These programs are listed below:
1. Adobe illustratorCS5
2. Adobe flash player
3. Adobe Flash builder CS5
4. Adobe Flash CS5.
Download these software and you will be able to see your file.
I am also going to add the link to download these files.
You can download it from here:
https://fileinfo.com/extension/fxg
Thanks
Tunacao Caaron.
Notifications
