Need some help with file format “.npf ”
Hi guys, I have some video files at the end of the file name it says .npf,
I never heard that file type before,
Please can someone suggest me a good program to open files with an extension of .npf?
Hi there,
I think you are having trouble with .npf format. You cane plays the video file right. Let me tell you what actually .npf is.
.npf is Nero sound Trax project file. But I guess its most probable an audio file like mso, cpi and all.
This is used for projects in Nero mainly.
Do a quick free scan for NPF file errors. You can find that in the following link respectively: –
Try the scan and if its run successful then try right clicking the file which you need to open and then select properties and in the file associations select Nero multimedia players and then proceed.
Hope it solves your problem.
